Hello fellow Outlander owners, I bought a 2021 2.4L 4WD new car in 2022. It usually drives fine, but it lacks power when climbing hills during trips. What could be the issue?
Comments( 7 )
Does anyone know why the 2.0 naturally aspirated engine with 6-speed wet dual-clutch can't shift gears in manual mode? How do you fix severe engine vibrations? But once you accelerate, there's no vibration. Also, there's an issue with lack of power when climbing hills. Last time, I almost got stuck in the basement because the engine revved up to 5000 RPM.
Hello MDX car owners, how many liters of engine oil do you usually add during maintenance? How many kilometers can you run? I used Mobil this year, added 5 liters each time, but the oil is almost running out after just over 5000 kilometers. It's burning quite a bit, is this normal?
I have a 2012 model with a 1.3 engine. Do you guys also experience a lack of power when climbing hills? Even when I press the accelerator hard, it feels like it's struggling.
4Today, while driving, the engine warning light suddenly came on. No other lights were on, but I felt the engine trembling and it lacked power. After driving for about 150 meters, during idling at a red light, the engine vibration was quite noticeable. When the light turned green and I accelerated, the trembling became more pronounced and it lacked acceleration. I pulled over immediately, waited for about 10 minutes, and after restarting, everything was back to normal. I restarted a few times afterward and everything was fine. The last time I started the car, I drove a few kilometers home and it was normal too. Has anyone experienced this issue? Does anyone know what might be going on?
5Hello fellow Outlander owners, I bought a 2021 2.4L 4WD new car in 2022. It usually drives fine, but it lacks power when climbing hills during trips. What could be the issue?
