As a new driver, I've only driven the 2019 2.0 model, and I find the acceleration quite sluggish. When I press the gas pedal deeply, the engine needs to reach around 1800-2000 RPM to speed up a bit, and the engine noise is quite loud. Is this normal for a naturally aspirated engine with a CVT? I tried using the DS mode, which seems to provide what I consider normal acceleration, but I noticed the RPM goes up to four or five thousand. My friend's 1.5T Geely doesn't make much noise and feels more powerful.As a new driver, I've only driven the 2019 2.0 model, and I find the acceleration quite sluggish. When I press the gas pedal deeply, the engine needs to reach around 1800-2000 RPM to speed up a bit, and the engine noise is quite loud. Is this normal for a naturally aspirated engine with a CVT? I tried using the DS mode, which seems to provide what I consider normal acceleration, but I noticed the RPM goes up to four or five thousand. My friend's 1.5T Geely doesn't make much noise and feels more powerful.
سلمان إياس
2024-07-17 18:29
Comments( 12 )
عبدالله فؤاد
عبدالله فؤاد2024-10-17 11:47
Switch to manual mode with paddle shifters.
خالد شادي
خالد شادي2024-09-22 21:24
Naturally aspirated and turbocharged engines can't be compared.
حسن عل
حسن عل2024-08-21 20:51
You might have high power requirements.
معتمد نايف
معتمد نايف2024-08-21 19:39
It's something you get used to — the 2.0 is really slow to start when the AC is on.
محمد عدي
محمد عدي2024-08-18 04:57
It only feels sluggish when you decelerate and then accelerate again; otherwise, it doesn't feel sluggish at all.
عبدالرحمن عثمان
عبدالرحمن عثمان2024-08-17 11:35
I feel you, let's just drive calmly! Otherwise, we might need to go for the 2.0T. If you're planning to overtake with a naturally aspirated engine, just switch to DS mode in advance! That's how I do it, haha! Not sure if it's the right way.
2
حسين أحمد
حسين أحمد2024-08-17 10:26
It's normal, very sluggish, only speeds up a bit between 40 to 80.
خالد يعقوب
خالد يعقوب2024-08-14 11:55
CVT transmission is not suitable for aggressive driving.
أحمد بهاء
أحمد بهاء2024-08-08 16:29
With the same engine displacement, the Qashqai accelerates faster than the Koleos. [I want some peace]
حسين هكيل
حسين هكيل2024-08-06 11:35
For such a big car, even my 2.4 struggles, let alone a 2.0. It's normal.
What could be the reason for the throttle of a 2003 S80 automatically revving up to four or five thousand RPM? [Facepalm]
How's the power acceleration of the Land Cruiser LTD? It feels quite sluggish.
What is the normal shift-up RPM for the Lancer 4AT transmission?
When I floor the accelerator on my 2.0T model, the RPM only goes up to 3000 and won't go any higher. Is this normal for everyone else's car too?
I have a 2023 Jietu X90 Zilong Changsheng version. When starting and accelerating, the engine roars loudly. Is it the same for everyone? There's no engine noise when it's idling, but as soon as I press the accelerator to start, the engine sound is quite loud.
Is it normal for the MG ZS to have sluggish acceleration and a rattling noise from the engine?
Is it normal for my manual comfort version car to have the engine rev up to 3000 RPM and make a lot of noise when driving over 100 km/h on the highway?
The T-Cross is terrible; the acceleration is sluggish. It only makes noise without actually speeding up.
Sometimes when I wait for the RPM to drop after starting the car, the engine noise is really loud. The sound gets louder or softer depending on how hard I press the accelerator, and the throttle doesn't feel as powerful as it usually does, requiring me to press it deeper. However, most of the time, this doesn't happen. After the RPM drops, the noise is normal.
Mitsubishi Mitsubishi Outlander
Mitsubishi OutlanderAED 96,495 ~ 153,000Gasoline & Hybrid
