What's causing the creaking sound from the chassis when I get out of the car in the garage? The echo in the garage makes the sound louder. Has anyone else experienced a similar issue? I have a 2021 model that I've driven for 20,000 km over two and a half years. When parking, I stop completely, shift to neutral, engage the electronic handbrake, then shift to park, turn off the engine, and get out. That's when I hear a creak from the left rear side.
I want to ask, how can I deal with the creaking sound from the rear seats of the T8?
When driving over bumpy roads, there's a suspected noise coming from the chassis around the rear axle area (a creaking sound). I want to ask if anyone else is experiencing this too?
Hi everyone, I have a 2016 3.6 Grand Cherokee. Recently, after switching to 0-20 oil, I've noticed a "doo-doo" sound coming from the exhaust area inside the car. It's not very noticeable when I get out of the car, seems like some kind of resonance. Also, after the oil change, the engine sounds louder. I've driven 400 km since then and there's no improvement. Any ideas?
4What's causing the creaking sound from the chassis when I get out of the car in the garage? The echo in the garage makes the sound louder. Has anyone else experienced a similar issue? I have a 2021 model that I've driven for 20,000 km over two and a half years. When parking, I stop completely, shift to neutral, engage the electronic handbrake, then shift to park, turn off the engine, and get out. That's when I hear a creak from the left rear side.
5Automatic parking makes a creaking noise when I press the accelerator to start. How can I fix this? It's not yet time for the first maintenance.
6What could cause a loud banging sound when I shift gears after the car has been parked overnight?
7When shifting from D to neutral, there is a clicking sound. What could be the problem?
8Why do I hear a sharp "squeak" sound when releasing the handbrake? This has only started happening in the past year.
9Is it normal for the Haval Jolion Comfort edition to lurch slightly when you park on a slope, shift to P, engage the electronic handbrake, and then release the foot brake?
10Do you have issues with window noise? When the car is parked outdoors, during rainy or very hot days, after starting, there's a creaking sound from the rooftop or windows, which disappears after driving for a while. I should mention that if it's parked in an underground garage, there's no noise. Even after reopening and closing the sunroof, the problem persists. When the noise occurs, it gets louder if the road is uneven. The model is a six-seater.
