حسين رشيد
حسين رشيد
Jun 15
I'm considering getting an old Outback and I'm torn between the late fourth generation and the early phase of the fourth-and-a-half generation. From what I've read, many posts say that the last EJ25 doesn't burn oil as severely as the first FB25.
عمر عوادة
عمر عوادة2024-06-27 09:02
Either the EJ25 before '12 or the FB25 after '15!
سلمان يوسف
سلمان يوسف2024-06-27 02:12
With a limited budget, consider 10-12 year old EJ models. These are older cars with a minimum of 200,000 km mileage. Maintenance can be costly, and there aren't many left that don't burn oil. Be cautious with 13-14 first-gen FB models. The 15-17 models are better, but those after 17 are the most ideal.
سعود خليفة
سعود خليفة2024-06-15 21:23
That must be the EJ25 from the 2010-2012 models.
I'm looking for a fourth-generation Toyota HiAce V8 with four-wheel drive. Does anyone know if it's available locally? I want to collect it, and I've been searching for it. Please leave a message if you have any information.
I have a 2019 GS5, and since early August, there's been a buzzing noise when driving between 60-100 km/h. It feels like I'm flying a plane, especially when I turn right, it gets louder. The dealership said it was a wheel bearing issue, so I had the bearings replaced, then the tires, and even the half shaft, but the problem still isn't solved. Has anyone else had this kind of issue? Please point me in the right direction. I don't want to keep wasting money and time on blind repairs. [About to cry]
When will Madoy release new models? Is there a general timeline? I'm currently torn between the new and old models.
Subaru Outback
Subaru OutbackSAR 123,000 ~ 204,000Gasoline & Petrol
