نايف إدريس
2024-07-30 13:10
I have a question for everyone. Occasionally, when opening the door of my 2021 Subaru Outback, the hazard lights flash a few times accompanied by a beeping sound, then it disappears. There's no indicator light on the dashboard, and there's no issue while driving. What could be the reason for this? I've been driving it for a few years and it's the first time I've encountered this situation.
When I start my car, the seatbelt indicator light flashes for a few seconds and then turns off automatically, even though I haven't fastened my seatbelt yet.
If the hazard lights don't flash and the trunk won't open when you press the key, what should you do?
When you open the door of a Sportage, do the hazard lights flash?
Does the 2020 model of Jetour X70 have an automatic flashing function, like hazard lights, when braking hard at high speed?
Hey car enthusiasts, any idea why the 2023 X90 Zilong Changsheng edition's hazard lights automatically flash 10 times after turning off the engine?
The engine malfunction light on my 2010 City recently started flashing. Diagnostic code 14 indicates irregular misfires. I've replaced the spark plugs, ignition coils, and cleaned the fuel injectors, but the issue still occurs intermittently. Every time the light flashes, I restart the engine and the issue disappears for a while before reappearing. Any knowledgeable experts or fellow car enthusiasts have any advice on how to handle this issue?
After ignition, the hazard lights automatically turn on and can't be turned off, but they disappear after turning off the engine. The hazard lights can be used normally otherwise. What's going on?
Haven't driven my car for a few days. Almost fell asleep when my neighbor messaged me saying my car's hazard lights were flashing. Went downstairs and sure enough, they were. No alarm, just the hazard lights. Couldn't turn it off with the key, so I had to get in, start the car, and turn off the hazard lights to stop it. Really bizarre.
How to set up the lock beep for the 2019 MG ZS Global Luxury Edition? The central control is already set to lights and beep, but when locking, only the hazard lights flash without the beep. Tried all the suggestions from Douyin and Baidu, but still can't get the lock beep to work.
Subaru Subaru OUTBACK
Subaru OUTBACKAED 114,900 ~ 135,000Gasoline
