عبدالرحمن ربيع
2024-04-05 23:14
I have a 2012 Subaru Outback with an EJ25 engine, almost 200,000 kilometers. It has noticeable shaking at idle and stalls during sudden braking, especially when the engine is cold. I cleaned the throttle body carbon build-up recently, which improved it a bit but didn’t completely solve the problem. The engine is quite loud during hard acceleration, and I’m not sure if it’s the engine or the transmission. Also, recently it shakes at speeds over 100 km/h. Anyone experiencing the same issues?
حسن دليل
حسن دليل2024-09-05 18:53
Brake stalling is an issue with the brake booster.
سلمان سعد
سلمان سعد2024-04-25 07:36
Brake stall, replace torque converter
حسين أزهر
حسين أزهر2024-04-24 08:16
Repair the torque converter.
علي سليمان
علي سليمان2024-04-07 14:50
You should find a mechanic, but here's a tip: definitely don't add carbon cleaner.
عبدالرحمن ربيع
عبدالرحمن ربيع2024-04-06 01:34
Is there still hope?
What could cause the steering wheel to shake during sudden acceleration? Today, when I suddenly accelerated, the steering wheel shook a lot, and I'm not sure what's going on.
I've got a 2013 Kia Sportage Manual GL 2.0, and the steering wheel shakes when idling. I've cleaned the carbon buildup in the engine cylinders, the injectors, and the idle valve. I also replaced the spark plugs and engine mounts last year. Any experts out there have any advice?
I have a 2009 Touran 2.0 manual, and I'm having trouble shifting into first and reverse. Is anyone else experiencing this? Also, when I release the clutch in first gear, the engine shakes like it's about to stall. It also shakes a bit during rapid acceleration. Is this normal?
Hi everyone, I need some advice. I have a 2015 1.4T Touran with nearly 110,000 KM on it. Recently, in the past six months, I've noticed that when making U-turns or reversing into parking spots, there's a sudden large resistance when turning the steering wheel. This doesn't happen during normal driving, only when suddenly turning the steering wheel. Can someone help me figure this out? Thanks!
Hello MDX car owners, how many liters of engine oil do you usually add during maintenance? How many kilometers can you run? I used Mobil this year, added 5 liters each time, but the oil is almost running out after just over 5000 kilometers. It's burning quite a bit, is this normal?
I've had my car for four and a half years and it's only done 36,000 km. It's a 2019 model with the 4J11 engine. Recently, when I start it cold, the engine struggles a lot. The RPM doesn't go up immediately, and the needle wobbles between 500 and 1000 for a few seconds, making it feel like it's about to stall. Then the RPM suddenly jumps to 2000-3000 before settling back to normal idle after a few seconds. There are no warning lights, and once it's running, everything seems normal. I've cleaned the carbon buildup and throttle, and checked the intake for leaks, but the issue persists. I'm not sure what to check next. What should I look into?
Hey car enthusiasts, has anyone experienced shaking during sudden acceleration? It shakes after driving steadily for a while, especially noticeable at high speeds. The 4S shop only cleared the previous driving habits, which improved slightly but didn't solve the root problem.
Subaru Subaru OUTBACK
Subaru OUTBACKAED 114,900 ~ 135,000Gasoline
