The battery status is normal. What could be the reason for not being able to start the engine after turning it off?
The car is difficult to start two hours after turning off the engine.
Has any xV owner experienced the issue of not being able to remove the key after the engine is turned off? How did you solve it?
What could be the reason for not being able to shift gears when the car is cold?
4After ignition, the hazard lights automatically turn on and can't be turned off, but they disappear after turning off the engine. The hazard lights can be used normally otherwise. What's going on?
5The battery status is normal. What could be the reason for not being able to start the engine after turning it off?
6What could be the reasons for not being able to shift gears?
7What could be the reasons for not being able to shift gears?
8Is it normal for a Cayenne's battery to drain to the point where it can't be charged after not being used for a month in the third year? After replacing it with a new battery, it drains after about 20 days of not being used. This has happened several times. Is this normal?
9The engine won't start, and the EPC, battery, and engine fault lights on the dashboard are all on. What could be the reason?
10The car won't start, and the EPC, battery, engine, and malfunction indicator lights are all on. What could be the reason?
