سعود غازي
2024-06-24 19:55
Is it normal for a car to lose its battery charge after being parked for a few days?? Please share your thoughts.
عبدالله مكتوم
عبدالله مكتوم2024-06-24 22:03
It's not normal. If I leave it for half a month, it always shows a reminder, but it can still start.
Can someone who's 189cm tall fit into this car comfortably? Could the experts please share their thoughts?
If I leave my car unused for three days, the battery dies. How long can your cars sit without losing charge? I'm thinking of getting an emergency jump starter. Could you recommend a good brand? Thanks!
Does it have the automatic parking and auto-exit from parking space feature? Otherwise, with parking spaces being so narrow these days, the automatic door opening feature is significantly less effective.
What should I do if my ES300h's battery is dead after being parked for half a month?
I've had my 2021 Jeep Compass for three years now. Last year, it was parked for half a month during the New Year, and the battery died, so I replaced it. In March this year, it was parked for over 10 days, and the battery was dead again. I replaced it with a new battery, and in May this year, after being parked for 9 days, the battery died again. What's going on?
What do you think about the three-cylinder Nissan X-Trail? Please share your thoughts.
How is the test drive of the Land Cruiser? How is the comfort? Please share your thoughts.
Is it normal for a Cayenne's battery to drain to the point where it can't be charged after not being used for a month in the third year? After replacing it with a new battery, it drains after about 20 days of not being used. This has happened several times. Is this normal?
MG MG One
MG OneAED 88,700Gasoline
