OMG the new BYD Yangwang U8 claims 0-100km/h in 3s! Worth the 500K SAR price tag or just hype? Let's discuss!
Any Accent owners here? I've been driving mine for over ten years without any issues. It just gets better with time. Even though I've bought a new car, I still can't let go of my old friend!
Choosing between the R+ and S+ can be quite a dilemma, especially in a second-tier city without a race track and if you don’t drive aggressively. You were initially considering the S+, but many people suggest going for the R+ or not buying at all. The significant improvement in 0-100 km/h acceleration is indeed tempting, but the price difference of 200,000 is quite substantial. It’s understandable that you’re feeling conflicted.
4I've always liked the style of the Prado with its spare tire on the back, but back then, I couldn't afford it. Now, the new model comes with a price range of 470,000 to 570,000 RMB. Considering today's car market and the current economic situation, spending over 600,000 RMB to get a Prado feels not worth it. Any tips or suggestions from you guys would be appreciated.
5Hey guys, I keep seeing on TikTok that the new Defender's price has dropped significantly with big discounts. Is this true or just marketing hype? If I buy now, will there be even bigger discounts later? Thanks, guys! Also looking for a 120k+ discount, with equal principal and interest, no penalty for early repayment, and the option to transfer at the dealership.
6Seeking advice for my first car (also just starting to drive). Budget around 400,000 RMB. Should I choose the Genesis with options or the new BMW 5 Series? I'm almost 35 and might have a child in the next 1-2 years. I feel like the Genesis doesn't have enough rear space, but I'm really attracted to its looks. The new 5 Series is quite controversial, but recently it's had significant price cuts, so I can afford the top trim, and it holds its value better. Could you guys help me decide?
7I'm just curious, what's the difference between a car that uses the complete BYD electric system and a BYD car itself? What are the advantages? I've been looking at electric cars in this price range recently.
8I just want to know who would actually buy this car? Isn't a BYD at the same price much better than this?
9Hey folks, does anyone use 98 octane fuel? I filled up with a tank of 98 yesterday and noticeably felt the engine noise reduced. Is this just psychological? Let's discuss it! 😄
