Why is it indicating that I need to change the oil again when I just changed it in March?
How do you reset the maintenance indicator, and how much engine oil is needed?
Can I replace just the headlight adjuster for the March, or do I need to replace the entire headlight assembly?
How many liters and what grade of oil is needed for an oil change?
4Do I need to remove the oil pan to change the oil?
5Do I need to remove the oil pan to change the transmission oil for the 2019 GAC GA5?
6How to check if the transmission oil needs to be changed?
7Does the transmission oil of the Jeep Compass 1.3T need to be changed? The manual says it doesn't need to be changed.
8Why is it indicating that I need to change the oil again when I just changed it in March?
9How much differential oil needs to be changed?
10The engine warning light is on, indicating an oil leak. I changed the oil 4 days ago using 5-30w. What's going on? Does anyone know?
