عبدالله عمر
2024-10-15 12:16
How do I clear the maintenance reminder?
تركي خالد2024-10-18 22:01
@BoboSha:
1. Turn off the ignition switch.
2. While pressing the clock adjustment button "SET," turn on the ignition switch.
3. Release the "SET" button, then press the "SET" button again.
4. Turn off the ignition switch, turn it back on, and check if it's reset to zero. If not, you must start over.
خالد سليمان2024-10-16 16:10
After maintenance, just ask the mechanic to reset it for you.
سعود عَبْدُ الله2024-10-16 07:35
I also want to cancel, not sure if it will have any impact.
