Has anyone encountered an issue with a 2017 Skoda Octavia where the gear doesn't shift up when accelerating, or it drops from D3 to D but doesn't move when accelerating? Any advice on how to fix this?
When the car is in D gear at idle, it feels weak (like an ant crawling), but when you press the accelerator, it becomes normal. In reverse gear, it doesn't move at all unless you press the accelerator. The car is a 2016 Haima S5.
Why does the car not move when I put it in gear, but only moves when I accelerate?
Are there any owners of the 2017 Skoda Octavia experiencing refrigerant leaks? The air conditioning suddenly stopped cooling.
4The 2012 Skoda Octavia 1.6 automatic makes a rattling noise during cold starts! There is a knocking sound when shifting gears!
5After replacing the battery on a 2017 Skoda Octavia 1.6 manual with low trim, the trip mileage, average fuel consumption, and other information on the dashboard reset to zero every time I lock the car for about 2 hours and then start it again. Has anyone encountered this issue or knows how to fix it? Please let me know. Thanks.
6When you shift to D gear and press the accelerator to start, does your car make a buzzing sound, like exhaust resonance?
7Why is there an impact when shifting from R to D gear?
8What type of engine oil should be used for the 2017 Skoda Octavia Automatic Intelligent Edition?
9Skoda Octavia Pro's large screen keeps rebooting automatically even when the car is locked and powered off. Is there any way to fix this?
10Has anyone encountered an issue with a 2017 Skoda Octavia where the gear doesn't shift up when accelerating, or it drops from D3 to D but doesn't move when accelerating? Any advice on how to fix this?
