Guys, I have a 2017 1.6 Zhixing. Last month, while driving, it showed a message to shift to P gear for repair, but it disappeared after a while. This morning, it reported a transmission fault, but after starting the car, it was gone again. What's going on?
I want to ask if anyone else has experienced this with the 720S: sometimes when I start it, a fault message pops up, but after driving for a while, it disappears on its own. When I check, it says there's no issue. Has anyone else encountered a similar situation? [Shocked]
The tire pressure warning on the third-generation Yuexiang keeps appearing. After driving for a while, it disappears. What's going on??
Why does the transmission often show a fault code and then disappear on its own shortly after?
4The engine fault code flashes at idle and stays on when starting. The fault indicates a misfire in cylinder two. After replacing the ignition coil and spark plugs, and cleaning the injectors, the fault code disappeared but returned after two days. Do you know what might be causing this?
5Guys, today I tried flooring it in Sport+ mode and heard a rustling sound that lasted about 5 seconds before disappearing. No error codes on the dashboard, and the car drives fine. However, when I parked and shifted to P, there was a continuous electrical noise. The noise disappeared after switching to neutral and back to P. Could there be an issue with the transmission? How should I check it?
6I bought it last month, and now the steering wheel pulls to the right while driving straight. Has anyone else encountered this issue?
7I was driving a Haima S5 1.6 CAT Creative Edition on the highway for about 6 hours, and suddenly the car couldn't accelerate. After stopping and turning off the engine for a while, it could accelerate again. What could be the problem? This has happened twice already, once on the highway before and once this year. When it couldn't accelerate, the car showed a fault code, but after parking overnight, the fault code disappeared. Has anyone else experienced this?
8After driving my car for a while, I keep getting notifications that the transmission needs maintenance. I've gone several times but it hasn't been fixed.
9Hello everyone, today after the car accident, it showed a transmission fault, and the gear can't be shifted from the P position. It seems like it's locked. What could be the problem?
10Guys, I have a 2017 1.6 Zhixing. Last month, while driving, it showed a message to shift to P gear for repair, but it disappeared after a while. This morning, it reported a transmission fault, but after starting the car, it was gone again. What's going on?
