خالد سا مرعي
2024-11-08 00:05
Does your naturally aspirated Octavia experience jerky shifts around 100,000 kilometers, especially between second and third gear?
There is a bit of a jerky feeling when shifting gears, and it lacks power when accelerating. What's going on? I've already cleaned the fuel system and replaced the transmission assembly. #JetourX95
The gear shifting feels jerky. When going downhill, just a tap on the brake slows it down to the minimum speed. The fuel consumption is too high, basically 11 liters in the city.
Is the strong jerkiness when shifting from 1st gear to 2nd in your GA8 a common issue, or is there a problem with the car?
Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
Hello everyone, is it normal for my 2013 Mazda 5 automatic to have a noticeable jerk when shifting from first to second gear, while other gears aren't as obvious?
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵‍💫 Do any other T-Cross owners experience this situation?
Hey folks, my 2017 Haval H2 manual is jerky between 1st and 2nd gear. It feels really tough to shift gears. What's going on here?
I want to ask if there is any jerkiness when shifting gears in the GA6.
[Shocked] What's up with this car? Starting in S mode, I floored the pedal, the RPM hit 4000 and it was still in 2nd gear without shifting up automatically. It only shifted to 3rd gear after releasing the throttle for 3 seconds.
The 2012 Skoda Octavia 1.6 automatic makes a rattling noise during cold starts! There is a knocking sound when shifting gears!
Škoda Skoda Octavia
Skoda OctaviaTBDGasoline
