محمد نواف
2024-10-27 20:44
Does anyone know what symbol represents the radio fuse for the Skoda Octavia Manual 1.4T? If you know, please reply. Thank you.
Hey fellow car enthusiasts, does anyone know which fuse is for the Korando cigarette lighter? Thanks!
Hey fellow car enthusiasts, does anyone know how to turn off the radio that starts with the car?? Thanks!
Is this car discontinued? If anyone knows, please reply.
Could someone please explain why the air conditioning evaporator box might explode in a Changan Yuexiang? If anyone knows the reason, please reply. Thanks!
The cigarette lighter fuse for the 1819 model of Yuxiang is located in the fuse box. You can usually find the fuse box under the dashboard on the driver's side or in the engine compartment. Please refer to the vehicle's manual for the exact location and diagram of the fuse box.
The fabric on the interior roof of my 2015 Skoda Octavia is coming off near the front windshield. Have any other Octavia owners experienced this? How did you deal with it?
To check the fuse for the front left low beam on a Skoda, you should first refer to your vehicle's owner's manual. The manual typically contains a diagram showing the location of the fuse box and details about each fuse. In most Skoda models, the fuse box is usually located either under the dashboard on the driver's side or in the engine compartment. Once you locate the fuse box, look for the diagram that indicates which fuse corresponds to the low beam lights. Make sure to replace any blown fuse with one of the same amperage.
What's causing water under the passenger seat and rear floor mat of the Haima S5? Where is it leaking from? If anyone knows, please reply, thanks!
Can the 2.0T Rui Shang be fitted with 20-inch wheels? Has anyone done it before? Please reply, thank you 🙏🙏🙏
After replacing the battery on a 2017 Skoda Octavia 1.6 manual with low trim, the trip mileage, average fuel consumption, and other information on the dashboard reset to zero every time I lock the car for about 2 hours and then start it again. Has anyone encountered this issue or knows how to fix it? Please let me know. Thanks.
Škoda Skoda Octavia
Skoda OctaviaTBDGasoline
