حسن جمال
2022-03-26 15:39
Will the NV200 be produced again in the future? Are there any other small vans like the NV200 available now? Don't mention Wuling Hongguang [shh]
نايف نصر
نايف نصر2022-03-30 12:34
Even if production resumes, you wouldn't buy it. The manual version is over 10, the automatic is over 12, and the luxury is over 13. The whole series basically has no features. Would you buy it?
صالح فهد
صالح فهد2022-03-30 08:16
With annual sales of just over 10,000 units, the manufacturer lacks the motivation to restart production. Even if production is resumed, it's highly likely to be an electric version.
سعود خليفة
سعود خليفة2022-03-28 23:02
If the price were a bit lower and the seating options ranged from 2 to 7 seats, it could be a big hit. 😁
خالد اسماعيل
خالد اسماعيل2022-03-26 19:05
It seems it will be difficult to resume production. You might want to look for second-hand or stock options.
Hey everyone, when you auto park your new GA8 and then start it again, do you hear a creaking sound? I haven't noticed that with other cars. Also, sometimes when braking automatically and the speed is close to 0, I feel the brake pedal jitter downward with a continuous noise. It's happened twice in 7000 kilometers. It doesn't affect the use, but I'm curious. Could this be a sign of a potential future issue?
I'm an owner of a 2012 XV and haven't really been to the dealership much. A few days ago, I went to get a small part replaced, and the manager mentioned that there's a recall for this model. It requires replacing the valve springs and brake switch, but it seems too troublesome since it needs the engine to be taken out, so I didn't do it. Has anyone else gone through this? If I don't do it, will there be any impact?
Can version 3.1.9 be upgraded? It seems that versions 3.0.3 and 3.1.2 were pulled back just a few days after their release. Version 3.1.10 was just released a couple of days ago and hasn't been pushed out yet. Currently, version 3.1.9 is being pushed in China. In the U.S., 3.1.9 was pushed out in early July, and it has been available in Europe for about a week. According to U.S. car enthusiasts on forums, some vehicles experienced a flickering issue with the 360-degree surround view in versions 3.0.3 and 3.1.2, where the screen would briefly go black and then light up again. After upgrading to 3.1.9, the issue was significantly alleviated during the first week, with flickering still occurring but only going black for 0.2 seconds and then automatically recovering, not affecting usability. However, the results after one week were not satisfactory, with the 360-degree surround view showing more frequent "camera unavailable" warnings than before, still severely affecting use. Yet, some car owners reported never encountering this issue (even with the problematic 3.x versions), so it might be related to a specific batch of parts or the vehicle's personalized settings. Have car owners in China noticed this issue after upgrading, or are there any other problems?
I've had my Ousheng for a year now, and after 15,000 kilometers, the engine started making a rattling sound like a tractor! I went to the 4S shop and they updated the software, which fixed it. Will this problem happen again in the future? I know a lot of people have faced this issue. If your car hasn't had this problem, please let us know. And for those who have experienced it, please share how you resolved it. 🙏🙏🙏
Hi everyone, I want to ask about the 2024 Cayenne. When I bought the car, there were no 21-inch wheels available, so I got the original 20-inch ones. Now I'm planning to change them. Should I go for the 20-inch bird's nest wheels or directly switch to 21-inch tires and wheels? I'm not very familiar with this. I've heard that 21-inch wheels might affect comfort and increase noise. A friend who repairs cars also says I don't need 21-inch wheels, but I'm worried I might regret sticking with 20-inch. Any advice?
Let me share my experience as well. I also have a 2017 MG ZS, one of the first batch from July, manual top configuration. Since then, apart from other issues, the main problem has been the car cutting off power when starting. The entire car loses power, and it won't start. It's fine today, but not tomorrow. The car often won't start. I've replaced several batteries and small parts, but the issue remains. Sigh, I'm disappointed. The car is still at the repair shop now, I'm afraid to drive it. If it stalls, it won't start again, which is frustrating. I used to be a loyal MG fan, but I'm really disappointed now. Next time I change cars, I won't choose MG anymore. Does anyone know what the problem might be?
