عبد العزيز خليف
2023-04-17 14:37
How did you solve the issue with the rear central air conditioning since the NV200 doesn't have central air conditioning?
سعود داود
سعود داود2023-04-18 11:44
If not available, you can install it later.
عبد العزيز خليف
عبد العزيز خليف2023-04-17 15:35
I didn't notice when I bought this car, there's no air conditioning in the back. Damn.
Hey folks, does the 2015 model have an air conditioning filter? Some say it does, some say it doesn't. Has anyone replaced the air conditioning filter before?
What could be causing the central lock switch on the 2018 Dongfeng Renault Koleos 2.0 to work intermittently? Has anyone else experienced this issue, and how did you solve it?
For the 2017 model, if the central control air conditioning vent is weak and you hear a loud noise from the air conditioning even when it's on maximum, but there's not much airflow, how can this be resolved?
I have a 2019 GS5 Elite version. Sometimes the central control screen doesn't power on, but the air conditioning works fine. The reverse radar is not usable, and the central control screen doesn't light up. Does anyone know why this is happening or has anyone else encountered this issue?
How did you guys solve the fuel pump belt issue of the 2017 MG ZS?
Is there anyone who has experienced noise from the passenger side when turning on the air conditioning in the 2019 GAC GA6? How did you solve it?
I want to ask if any of you have noise issues with the central control? How did you solve it?
Has anyone else experienced the issue where the car's data is turned off by default these past two days, and you have to manually turn on the network? How did you solve it?
2016 model Touran L's air conditioning starts cooling, but stops after a while. Replaced the solenoid valve and cleaned the control board, it worked for two days and then the issue reoccurred. Has anyone experienced this? How did you solve it?
