عبدالله عوادة
Apr 16
Will the Teana come with a 1.3T engine and steel chain CVT?
When I was driving my Toyota Yizhi with the CVT in D gear and stepped on the gas to 4000 RPM for overtaking, I suddenly felt a lack of power and then it sped up. They say this is the steel belt slipping, and driving like this can damage the transmission. I'm frustrated. What happens when the steel belt slips? Can any experts explain this?
Is there a 2012 model of the Teana with a 2.5 V6 engine? Can you help me?
The Toyota Yizhi 1.8-liter engine uses a timing chain.
4Will the timing chain of the 2017 automatic luxury version engine stretch?
5Will the Teana come with a 1.3T engine and steel chain CVT?
6The engine in the Iveco Ousheng 2.0 uses a timing chain.
7The 80th Anniversary Edition car with a 1.3T engine showing a battery voltage of 12.1V when running seems a bit low, doesn't it?
8Is the CVT in the Setus a steel chain or steel belt? The 7.99 version only lacks those two LED lights, right? It still uses halogen lights. I was initially considering the new TuYue 799 version, but when I saw that even the spare tire was downgraded, I was immediately discouraged. Now I'm looking at the Honda Binzhi and Setus. The Binzhi is 10,000 more expensive, so I'm considering the Setus. The only concern is why the headlights are still halogen.
9Has anyone replaced the high-pressure fuel pump and timing chain on a 1.6L engine?
10Is the transmission in the 2019 Murano using a steel belt or a steel chain?
