My car got hit while parked in the neighborhood, and there's a dent about the size of an ID card above the right front wheel. I'm considering paintless dent repair. Has anyone done this before? How was the result?
Hello fellow car enthusiasts! The new model of the Sequoia probably isn't available in the Chinese market yet, right? I'm planning to get a full-size SUV and looking forward to seeing the actual vehicle before making a decision.
Just got it home and looked in the garage, the front is lower on the left and higher on the right. Measured with a ruler, there's a 2 cm difference.
After replacing the front suspension arms on my 2014 compact car, the steering wheel feels much lighter and not as stable as before. I took it to a repair shop, and they changed the valve core, saying it was a tire pressure issue. However, the light steering feel returned shortly after. I've already done wheel alignment and balancing, but haven't changed the power steering fluid. What could be the reason for this?
4There's a scraping noise coming from the right front wheel of your 2013 Nissan Sunny, and it's particularly loud when you brake. It sounds like metal scraping. The car has done 150,000 kilometers, and the brake pads are of moderate thickness. The repair shop says there's no need to replace them. What could be the issue?
5My car got hit while parked in the neighborhood, and there's a dent about the size of an ID card above the right front wheel. I'm considering paintless dent repair. Has anyone done this before? How was the result?
6Does anyone know the size of the air conditioning filter for the 2019 GAC GA6? I've bought many, but they're all a bit thin. I got one from the store before that fit perfectly. This filter is thicker than the usual ones!
7I have a 2018 Outlander 2.4 AWD. Last month, the right front wheel got hit, and I had to replace the shock absorber, half shaft, and steering rack. 😒😒😒 Now, when I'm driving at around 110 km/h, the steering wheel vibrates in my hands. It's not exactly a shake, but more of a tingling feeling. The car doesn't drift or vibrate, just the steering wheel. If I grip the wheel tightly, it feels a bit better. There's no issue when driving below 100 km/h. I've done wheel alignment, and the data is spot on. I've also done wheel balancing and swapped the front and rear tires. I've even replaced the front bearings, but there's no change. The repair shop said the next step would be to start replacing parts one by one, but that would be too costly. Does anyone know what the problem might be? I'd be willing to offer a small reward for a solution. 😏😏😏
8Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
91.8L 2017 automatic luxury model with just over 50,000 km on the odometer. It's a red car with quite a few scratches on the exterior. It had a front-end accident but only needed a front set replacement, no damage to the frame. The right rear door has some bodywork done. However, the engine, transmission, air conditioning, and car system are all in excellent condition. You can test it out before deciding. It's a great choice for practice driving.
10The front windows of the Jetour X70 cannot be opened, and the horn alarms when the car is locked with the remote. When the unlock button on the remote is pressed and held, only the rear windows open, while the front windows do not respond. I had this issue repaired at the 4S shop before, and they said it was related to the fuse. However, the problem has occurred again just two to three months after the repair.
