Is it necessary for the 2021 Nissan Teana to be recalled by the manufacturer for EGR valve replacement?
Is it necessary to replace the sensor if there's an oxygen sensor 2 circuit fault?
I'm torn. Is it really necessary to buy the sport version of the Nissan GTR?
4What's the situation with the 2019 X-Trail EGR valve recall, and should it be replaced?
5Fellow car enthusiasts, how often do you replace your solenoid valves? Mine needs replacing every year, and this year I've already replaced two.
6Has the T-Cross been recalled for a fuel pump replacement at the 4S shop? Have you noticed higher fuel consumption after the fuel pump was replaced?
7Is it necessary to replace the accessory belt when changing the timing belt?
8For the 2021 model of the Tiida, what maintenance is necessary at 60,000 kilometers? I don't want to waste money!
9Does replacing the valve cover gasket and reapplying sealant on the 2021 Forester require lifting the engine? Both the 4S shop and outside mechanics say that the new engine bay has become smaller and that lifting the engine is necessary to replace the valve cover gasket. Is that true?
10Can owners of the 2021 Nissan X-Trail play video songs while driving?
