حسين رشيد
حسين رشيد
Nov 29
I'd like to ask everyone, do you also have to close the rear door of the T-Lai Zhenxin version with a lot of force? I just got mine and it's really hard to close. I have to use a lot of force every time and it makes me feel bad. Is this how the car is, or is there an issue with the door?
لحود أحمد
لحود أحمد2024-11-30 23:52
The car's design itself. It won't be difficult to close after a couple of years. 😬
يعقوبي سلمان
يعقوبي سلمان2024-11-29 12:59
I also got the Deluxe Edition yesterday.
Why won't the electric sliding door lock properly? I have to press it with my hand to fully close it.
Why won't the electric sliding door close properly? I have to press it with my hand to get it to lock.
I'd like to ask fellow car owners, when you turn off the car and park it in P gear, does it move slightly when you release the brake? Mine has been doing this a lot lately.
Is it normal for the doors of a Mitsubishi Eclipse Cross not to close at -20°C and require extra force to shut properly?
Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
I've got a 2016 manual Vitara, and I've noticed marks on all four door screws. It's a used car, so I'm worried the doors might have been repaired. Do other owners have the same issue?
Does anyone have the repair manual for the 2015 five-door Mini Cooper? A Baidu Cloud link would be greatly appreciated, thanks a lot!
Why do I feel that the soft-closing mechanism on the rear door is less sensitive than the front door? With the same amount of force, the rear door doesn't close properly. Do you guys experience this too?
Once the speed reaches 80, there's a lot of wind noise, and the doors feel like they're leaking air, but I can't find the exact spot. Is this a common issue or do the doors have a problem?
I'd like to ask the owners of the Defender 110, does this car have a lot of problems? I'm considering buying it; it looks beautiful inside and out. Thanks.
Nissan Altima
Nissan AltimaEGP 1,515,945 ~ 1,903,288Gasoline & Petrol
