سلمان محمد
2024-12-01 13:34
Has anyone experienced the situation where the car doesn't move when in reverse with the steering wheel fully turned and the brake released? You have to give it a little gas to get it moving. This can be quite dangerous when reversing. It's the 7th generation Nissan Altima.
نايف عبد لطيف
نايف عبد لطيف2024-12-03 16:06
It's normal. Many cars, not just the Teana, require you to turn the steering a bit before they move. Another reason could be that your parking brake isn't disengaged.
حسين خضير
حسين خضير2024-12-02 22:31
The auto-hold feature is on, right? You need to give it a little gas.
محمد عفان
محمد عفان2024-12-01 14:55
Haven't encountered this before, could it be because of winter?
عبدالله مستعصم
عبدالله مستعصم2024-12-01 14:11
You really have to beat me up [I want to be alone][I want to be alone]
Hey guys, my automatic Kia Sportage isn't moving when I shift into reverse. It only starts backing up when I give it some gas. Any ideas?
Nissan Patrol, 98k kilometers. Now when I turn the steering wheel all the way, it gets stuck, and I can't turn it. Also, when reversing, it doesn't move. Has anyone else experienced this issue?
What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
My One suddenly won't move when I press the gas while in D gear today. It feels like something is dragging it. Any fellow car enthusiasts know or have encountered this situation before?
Why does the newly purchased car make a slight noise when moving forward with the left rear wheel, but not when reversing?
I have a 2022 model Roewe RX5 MAX 1.5T. When I step on the gas in reverse, there's a "clack" sound. If I don't press the gas while reversing, there's no sound, but as soon as I do, there's a loud and very noticeable "clack" noise.
I have a 2019 Jeep Compass 1.4T. When I put it in reverse and give it gas, there's a "thud" sound sometimes, but not always. Does anyone know what's going on? I checked with a mechanic, and they said it's normal for a dry dual-clutch transmission. Can anyone confirm this? Thanks.
When driving over 80 and letting off the gas, there's a booming noise from the front, but it stops if you give it a little gas. Does anyone know what's going on? 😲
Hello everyone, when driving an automatic Nissan Sunny, what's the situation when I brake and then accelerate, the RPM goes high but the car doesn't move? This often happens when turning as well, the RPM is high but it just doesn't go.
Nissan Nissan Altima
Nissan AltimaAED 110,000 ~ 146,500Gasoline
