Need D-Max diesel for carrying equipment. Can the trunk fit 4 large boxes?
Can a McLaren 570GT be fitted with a roof box?
Can a 24-inch suitcase fit in the front trunk of a McLaren GT?
The air conditioning filter in the S40 is typically located behind the glove box. To replace it, you generally need to follow these steps: 1. Open the glove box and empty its contents. 2. Gently unhook the glove box to allow it to drop down further, giving you access to the filter compartment. 3. Locate the air conditioning filter cover, which is often held in place by clips or screws. 4. Remove the cover to access the filter. 5. Take out the old filter and insert the new one, ensuring it is positioned correctly according to the airflow direction indicated on the filter. 6. Reattach the cover, secure the glove box back in place, and close it. Always refer to the vehicle's manual for specific instructions, as the process can vary slightly depending on the model year.
4Can this type of car be used as a personal vehicle? I won't be carrying passengers, and I have an A1 driver's license. Do I need any other permits?
5How long is the trunk? Can it fit a 2.4-meter motorcycle?
6Due to work, I've moved to a rural area and I'm considering buying a four-wheel drive vehicle. My options are the Haval Raptor and Subaru XV. I want to ask friends here, is the trunk of the XV spacious enough? I have a two-month-old baby and often need to carry a stroller. From the photos, the XV's trunk doesn't look very large. Also, there's a common issue with boxer engines consuming oil—does the XV have this problem too?
72019 Roewe RX5 MAX automatic 4G Internet luxury model, the trunk won't open, can only be opened with the key. Does anyone know what might be going on?
8Are second-hand four-wheel drive high-end models equipped with a factory-installed large screen infotainment system, or do I need to install it myself?
9Can the trunk of the Nissan Murano fit four 28-inch suitcases?
10Can the Lingfang 2.0 Luxury Edition be equipped with a roof cargo box?
