ماجد سعود
2025-02-20 14:31
Need a reliable pickup for my construction business. Is Hilux 2024 worth the hype? Or should I go for cheaper options?
صلاح أحمد
صلاح أحمد2025-02-20 14:31
Hilux is the GOAT for a reason! I’ve had mine for 5 years, 250,000km, zero breakdowns. Tows 3.5 tons, handles desert heat like a champ. Yes, it’s AED 145k (base model), but resale is 70% after 3 years. Cheaper options (like Chinese brands) won’t last 2 years in GCC conditions.
خدي خالد
خدي خالد2025-02-20 14:31
Get the 2.8L diesel – more torque, better fuel economy (8.5L/100km).
Is the 2014 2.0T worth buying for 52,000? Or should I go for the 2017 1.5T?
In your 2019 GS5, if you want to turn off the colored circle touch assistance on the center console, similar to the assistive touch on an iPhone, you might need to check the vehicle's settings menu. Look for options related to touch or display settings, and there should be an option to disable this feature. If you're not sure, consulting the user manual or contacting your local dealership for guidance might be helpful.
Hey guys, I've saved over 60k, and my annual income is just under 70k. Can I go for it? My family is strongly against it [I need some time alone] What should I do?
If you're 27, with your family contributing 200,000 yuan, and you have a monthly salary of over 8,000 yuan, you can consider adding some money to buy a decent car. Depending on your preferences and needs, you might look at brands like Haval or BYD for reliable options. Keep in mind the fuel economy and horsepower that suit your driving habits.
Where should I go for maintenance? Do I need to make an appointment, or can I just go directly to a 4S shop like with traditional cars?
For the Prado 120, when choosing a rear lock, should you go for an electric lock or an air lock? If you choose an air lock, you will also need to buy an air pump, right?
Is it still worth buying the Venza if it's going to be discontinued after the 2024 new model release?
I have paid off my car loan and received the green title, but I forgot to lift the lien. A year later, when I went to do it, they told me the company had gone bankrupt and I need to get a new business license. What should I do in this situation?
I want to buy an Alto, should I go for a manual or automatic transmission? Locally, there's a 2013 model that's priced around 13,000 and has run about 80,000-90,000 kilometers. Is it worth buying if it's a manual transmission?
Hey guys, at 90,000 km, do I need to change the spark plugs? If yes, should I go for Champion or Mopar?
Toyota Toyota Hilux
Toyota HiluxAED 77,000 ~ 169,900Diesel & Gasoline & Petrol
