Can I use a USB drive to listen to music?
It seems like the Peugeot 207 doesn't have a USB port. How can I connect my phone to listen to music?
Can the LinkTour Yun Kuanyue Xiang play music from a USB drive?
What should I do if I can't use the USB port to play music?
4Can the 2018 Renault Koleos play lossless music from a USB drive?
5Why does the car disconnect when listening to music via a USB drive? How can this be resolved?
6Can I use a USB drive to listen to music?
7Do any of you use a USB drive to listen to music? Does the USB drive need to meet certain requirements? Why can't the songs I downloaded on my previous USB drive play? I used a card reader with a memory card, and it worked before, but now it always switches back to the radio interface.
8Can the Cetus car play music online, or can it download apps to play music, or is it only possible to use a USB drive?
9What formats does the USB interface support? I'm planning to use a USB drive to play lossless music, and I'm not sure if it supports APE format.
10The 2020 model only has one USB port. If you plug in a USB drive to listen to music, you can't connect the car kit. The USB extension ports you bought aren't working, and the USB in the armrest cigarette lighter also doesn't support USB drive for music or connecting the car kit. Do you have any suggestions for using both the USB drive for music and the car kit simultaneously?
