نايف بكر
2022-05-20 12:23
The gear lever on this company car is problematic. After shifting to reverse, the detent stays in the engaged position even when you return it to neutral. You have to push it down to disengage. I didn't pay attention today, and when coasting downhill while pressing the clutch, I directly shifted to first gear without pushing the detent down. As a result, the car stalled and now it won't start at all.
عبد العزيز جم دين
عبد العزيز جم دين2022-09-26 22:06
Sometimes I can't shift into reverse gear with the manual transmission. I need to move forward a bit and straighten the steering wheel to get it into gear.
لطيف سعود
لطيف سعود2022-06-11 01:36
There are benefits to driving more often. Our company also uses this car. The manual transmission is really comfortable.
Is your 2018 manual KIA Pegas with 70,000 km experiencing difficulty in shifting gears, often failing to engage and grinding? It seems like the clutch isn't fully disengaging. Could this be a clutch issue or a problem with the gear linkage? How can it be resolved?
The gear shifting feels jerky. When going downhill, just a tap on the brake slows it down to the minimum speed. The fuel consumption is too high, basically 11 liters in the city.
Hey folks, I have a question. My car can't shift gears. When the engine is off, the gear lever can move freely, but when the car is on, it's like something is blocking it, and it won't go into gear. It's a manual transmission, and I can't shift into any gear from 1 to 5 when the car is on. Does anyone know what the problem might be? Thanks 🙏🙏🙏🙏
Is it a problem with the gearbox if sometimes the 4th gear won't shift down to the 3rd gear in a 2015 Honda City with a manual transmission? Waiting online for someone knowledgeable about cars to answer.
I have a question. Today while driving, I noticed that the gear shift lever on my automatic transmission can be shifted without pressing the button on the handle. Is this a problem?
What could be the issue with the 2019 JETOUR X70 having difficulty shifting gears? The clutch master cylinder and transmission have already been replaced, and the issue has somewhat improved. However, sometimes it's still hard to engage first gear.
Hi everyone, when I'm accelerating with my FJ and shifting gears, I notice that the shift from 4th to 5th gear feels more pronounced and abrupt. Is this normal? There are no error codes. It's not noticeable during normal driving, but if I deliberately pay attention to each gear shift, I can feel a slight jolt from 4th to 5th. To notice this, I have to keep the throttle steady without releasing or pressing it more. During the 4th to 5th shift, there's a noticeable abrupt feeling. However, if I ease off the throttle during the 4th to 5th shift, there's no issue at all. Any thoughts or suggestions are welcome. Thanks!
Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
How do I shift gears when driving a Setus down a long slope?
Nissan Nissan Navara
Nissan NavaraAED 69,000 ~ 113,085Diesel & Gasoline & Petrol
