عبدالله هشام
2023-05-08 20:34
Navara 2019 model, currently has over 60,000 kilometers. When changing the spark plugs, there was oil in the cylinders. The 4S technician said the valve cover needs to be replaced due to internal leakage and should be replaced together. I want to ask everyone, is this a common issue with the Navara?
عبد العزيز نور
عبد العزيز نور2023-05-09 18:41
It definitely isn't, does your car burn oil? If it doesn't, it might just be a slight seal issue with the valve cover. The seal is a rubber ring, which can age over time. However, if you take care of it regularly, it shouldn't be a problem. You should know that the valve cover of a BMW is considered a wear-and-tear part and needs to be replaced every 100,000 kilometers. Brother, make sure to pay more attention to maintenance.
10 Mazda 3 Star Version 2.0 frequently has the warning light on, with an instant fuel consumption of 30-40 at startup. Spark plugs, intake manifold solenoid valve, rear oxygen sensor have been replaced, throttle body and mass air flow sensor have been cleaned, but the light comes on again. The first row mixture is too lean. Any suggestions?
When coming to a stop, the idle speed suddenly drops and it feels like the car is about to stall. This occasionally happens when shifting from D to P while stationary. I've replaced the spark plugs, ignition coils, injectors, high-pressure fuel pump, PCV valve, carbon canister solenoid, air flow sensor, and engine mounts. I've also cleaned the intake carbon deposits and combustion chamber carbon deposits. The problem still exists. Can anyone help me figure this out? [crying][crying][crying][crying]
Is there a solution for the Kia Sportage valve cover oil leak? Is it a common issue? I bought a 10-year-old manual second-hand car.
Hello everyone, has anyone experienced this with the 2019 model 35p automatic? Currently, I've driven 60,000 kilometers, and occasionally when I brake at a red light, the idle speed fluctuates. How did you deal with it? I've cleaned the throttle and replaced the spark plugs, but I still don't know why it's happening.
I'd like to ask Mazda 5 owners, why is the noise level so high in this car? How can it be resolved, and how do you deal with valve cover oil leakage? What are your Mazda 5's fuel consumption rates in the city and on the highway? My 2011 automatic Mazda 5 costs 0.9 RMB per kilometer in the city.
I've got a 2013 Kia Sportage Manual GL 2.0, and the steering wheel shakes when idling. I've cleaned the carbon buildup in the engine cylinders, the injectors, and the idle valve. I also replaced the spark plugs and engine mounts last year. Any experts out there have any advice?
Does replacing the valve cover gasket and reapplying sealant on the 2021 Forester require lifting the engine? Both the 4S shop and outside mechanics say that the new engine bay has become smaller and that lifting the engine is necessary to replace the valve cover gasket. Is that true?
Nissan Nissan Navara
Nissan NavaraAED 69,000 ~ 113,085Diesel & Gasoline & Petrol
