حسن طارق
2022-08-17 19:45
Just got it home and looked in the garage, the front is lower on the left and higher on the right. Measured with a ruler, there's a 2 cm difference.
عبد العزيز هارون
عبد العزيز هارون2022-08-22 10:46
The national standard is less than 40mm, which is normal because the left and right cannot be completely symmetrical and can be adjusted. 😊
Why can't the front left and rear left doors of my Mazda 5 be raised or lowered?
Why do the brake lights look different on the left and right, and why is the left light not working?
I just got a 206, and I've noticed that the body is lowered. Is it coilovers or lowering springs? I noticed the rear chassis is different from regular cars. Any advice?
Is the heads-up display text in the RDX slightly higher on the left and lower on the right?
Can I plug a home charger into the fast-charging port on the left side, considering that my parking space has more room on the left and the right side is against the wall?
Just got the car 2 days ago. When I picked it up, it showed 435, but it seems like I've only driven less than 300, with a bit over 90 left, so I went to charge it. Is this normal for city driving?
For the 2017 BRZ, the lower trim and higher trim, specifically the S and RS versions, besides the difference in suspension, is there a difference in the central control? I noticed some websites show the RS version with a touchscreen central control while others show it with a basic single-disc radio central control.
Is there a problem if the tire pressures are different? Front left 240, rear left 250, front right 240, and rear right 233. Is it okay to drive?
Nissan Nissan Navara
Nissan NavaraAED 69,000 ~ 113,085Diesel & Gasoline & Petrol
