Hello fellow car enthusiasts, I just bought a Navara. I noticed that the reverse camera image shows things a bit farther away, but in reality, they're much closer. Is there a way to adjust it to appear closer? I'm not quite used to it!
Hi everyone, I'm asking a question here about owning an 86. I want to buy an 86 as my first car and I have enough money for a 2017 model. Does the 2017 model come with a reversing camera? Can I install front and rear parking sensors later? I'm quite reliant on sensors. If it doesn't come with factory sensors, can they be added afterward? Looking forward to your replies, thanks!
Why won't the panoramic image open? Clicking it doesn't respond, and it also doesn't switch to the camera when I put it in reverse gear. What's the reason?
4Have you encountered a situation where the reverse camera image is missing the borders and only the image is displayed? How can it be restored to normal?
5If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
6Hello fellow car enthusiasts! Why is the reverse camera on my 2013 Sharan 2.0T showing the left and right sides reversed?
7Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
8Hello everyone, when I start the car and reverse while turning the steering wheel, does anyone hear a noise from the lower control arm? It goes away after a while! My car has done 110,000 kilometers. The engine also makes a rattling noise when starting, and the RPM is over 1000, but it settles down in a few seconds! I suspected the chain, but since the RPM is also high, I ruled that out! Has anyone experienced something similar?
9I feel like the reversing camera image is not clear. Can I replace the camera individually?
10Does anyone know how to adjust the brightness of the 2017 Skoda Kodiaq's infotainment system? I got a second-hand one, and I can't see the screen at all during the day. The reverse camera isn't visible either. I've already set the brightness to the maximum, but it's still not clear.
