Does the gear stick shake when starting a manual transmission car?
What causes the Yaris to shake when starting?
I want to ask fellow car enthusiasts, for those with dual-clutch transmissions, does your engine shake like a manual car about to stall when you're in a traffic jam?
4Why does the Changan Yuexiang jerk when starting in D gear?
5Why is my 2018 1.6 manual transmission car having unstable idle when cold started?
6Manual transmission starting shudder
7How many liters of gear oil does a JETOUR X70 manual transmission require?
8Is it normal for the car to shake when downshifting from 3rd to 2nd gear while braking?
9What could cause a car to shake when starting cold?
10Does starting in second gear damage the car?
