To activate the cruise control on the MX-5 NC, first make sure you're driving at your desired speed. Then, locate the cruise control button on your steering wheel or stalk and press it to turn on the system. Once activated, you should see a cruise control indicator light on your dashboard. Adjust the speed using the "Set" or "Resume" buttons as needed.
"The electronic shift backup has been activated; please service soon." This message indicates that there might be an issue with the electronic gear shifting system in your vehicle. It's recommended to have it checked and serviced by a professional as soon as possible to avoid potential problems.
Why can't the cruise control on the LC300 be activated? It shows OFF and won't turn on no matter what I do.
4I'd like to ask fellow car enthusiasts about the fuel consumption display of the Scirocco when cruising at a steady 120 km/h on the highway during the Spring Festival. Please specify your model, like 1.4T single turbo 7-speed showing xxx fuel consumption at 120. I'm just looking for a reference because I'm considering buying a fuel-efficient car with cruise control for highway driving. I think the Scirocco 1.4 single turbo is pretty good, but I've heard that the 2.0T 6-speed is also very fuel-efficient.
5What is the maximum speed of the X cruise control?
6How do you activate cruise control on a 2017 Smart? I've been trying for a long time but still can't figure it out.
7The difference between canceling cruise control and turning off cruise control in a Patrol is essentially about how the system is deactivated. Canceling cruise control is a temporary deactivation, allowing you to resume the set speed later, while turning off cruise control completely deactivates the system until you set it up again.
8The difference between the "Cancel Cruise" and "Turn Off Cruise" buttons on the steering wheel of a Patrol is as follows: - **Cancel Cruise**: This button temporarily deactivates the cruise control while keeping the set speed in memory. You can resume the cruise control to the previously set speed later without having to set it again. - **Turn Off Cruise**: This button completely deactivates the cruise control system and clears the set speed from memory. To use cruise control again, you would need to set the speed anew.
9The issue with the cruise control not holding could be due to several reasons. While the indicator light on the dashboard shows that the cruise control is activated, it might not maintain the set speed.
10To turn on the heater without the AC light coming on, you usually need to adjust the settings on your car's climate control system. Make sure that the AC button is turned off. If your car has an automatic climate control system, try switching to manual mode and adjusting the temperature and fan settings manually. If the AC light still comes on when you activate the heater, it might be due to the car's design to dehumidify the air, in which case you may need to consult your vehicle's manual or contact a service center for further assistance.
