عبدالرحمن نظيف
عبدالرحمن نظيف
Dec 10
Hurry up and enter China! Otherwise, you'll be pushed out by electric vehicles. I really don't understand Mazda's planning. The MX-5 also has a low presence in China...
هارون أحمد
هارون أحمد2024-01-14 10:37
Why can't it get in? Because the car is too light. The fuel consumption can't go down. The weight-to-fuel consumption ratio doesn't meet the standards. So this fuel car can only be bought as a parallel import. The ND3 might be the last chance. Anyway, I'm planning to sell it.
علي صعدة
علي صعدة2023-12-18 19:41
Are you coming in to buy?
وسيم عبد العزيز
وسيم عبد العزيز2023-12-17 20:56
With a budget of 400,000 RMB, it feels like getting completely ripped off.
عبد العزيز علي
عبد العزيز علي2023-12-10 11:53
No one is buying, so why come in?
How can the original Mazda MX-5 NC head unit connect to a smartphone to play music?
What type of transmission oil should I use for my Mazda 5? Planning to change it, thanks.
Congratulations on getting your benefits! If you're planning to get a Cullinan but are new to driving, here are a few tips for beginners: 1. **Take Driving Lessons**: Consider enrolling in a driving school to get professional training. 2. **Understand the Vehicle**: Familiarize yourself with the features and controls of the Cullinan. It's a high-end car with advanced technology. 3. **Start Slow**: Begin practicing in less busy areas to build your confidence. 4. **Safety First**: Always wear your seatbelt and follow traffic rules. 5. **Get Comfortable**: Adjust your seat and mirrors before driving to ensure you're comfortable and have good visibility. 6. **Parking Practice**: Spend time practicing parking, as it can be challenging for new drivers. Once you're confident with these basics, driving your new Cullinan will be an enjoyable experience!
To replace the dust cover on the gear lever of a 2018 manual transmission ZS, follow these general steps: 1. **Remove the Gear Knob:** First, unscrew or pull off the gear knob, depending on its attachment method. 2. **Detach the Dust Cover:** Carefully pry off the trim panel around the gear lever to access the dust cover. This might require a trim removal tool to avoid damaging the panel. 3. **Remove the Old Dust Cover:** Once the trim is removed, you'll see how the dust cover is attached. It might be clipped or screwed in place. Remove any fasteners and take off the old cover. 4. **Install the New Dust Cover:** Position the new dust cover in place, ensuring it's aligned correctly. Secure it with the clips or screws you removed earlier. 5. **Reattach Trim Panel:** Pop or screw the trim panel back into place around the gear lever. 6. **Reattach Gear Knob:** Finally, screw or push the gear knob back onto the lever. Note: These steps are a general guide. It's always best to refer to the vehicle's manual or consult a professional for specific instructions related to your car model.
Mazda MX5
Mazda MX5TBDGasoline
