My car's trunk won't open electrically; I have to use force to open it manually.
The trunk won't open, what's going on? Is there a switch inside? Thanks.
Why won't the trunk of my 2008 S40 open? What could be the reason?
The trunk of the S40 won't open, what's the issue?
4Where is the button to open the trunk if it won't open?
5My M7's electric right middle door isn't working. It opens a little, and if I press it again, it opens a bit more, but it won't close completely. Experts, what could be the reason for this?
6The trunk suddenly won't open, and it's showing that the trunk is unlocked. What could be the reason?
7The trunk of my Scirocco can't be opened using the driver's seat switch, but I can open it with the key. What's going on?
8The trunk of my Rapid won't open. Is there a solution?
9Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
10My car's trunk won't open electrically; I have to use force to open it manually.
