خالد يونس
2024-08-23 15:55
I noticed occasional vibrations in my Murano at around 20,000 km, and the vibrations don't last long. When I went to the dealership for maintenance, they mentioned that they could replace the mid-section improvement part with a bracket for free. Has anyone had this replaced? How does it feel after the replacement?
Comments( 9 )
علي يسار
علي يسار2024-09-04 22:22
A while ago, the 4S shop called me to offer a free exhaust pipe replacement. I had my wife go and get it done. They said it would fix the resonance issue. It seems a bit smaller, but it's okay! You might want to contact the 4S shop to check.
عبد العزيز مراد
عبد العزيز مراد2024-09-03 13:42
I bought the car and did the first maintenance at the 4S shop, but I've done all the other maintenance outside since then. It's currently at 150,000 kilometers. The vibration is really obvious, and this issue seems to have been there from the start. The exhaust pipe has already cracked once due to the vibration, and I had it welded at a local shop. Not sure if it'll crack again later. 😅
سعود ثاني
سعود ثاني2024-09-02 14:56
Is resonance noise loud?
عمر عمر
عمر عمر2024-08-28 08:47
Replacement requested proactively by 4S before the warranty period ends.
عبد العزيز محسن
عبد العزيز محسن2024-08-27 21:26
I went for maintenance, and the technician directly asked me if I wanted to replace it for free, and then just replaced it.
فهد أبشير
فهد أبشير2024-08-24 05:40
It's better to replace it than not. The ones with a bracket can prevent the bronchus from cracking and also help reduce the resonance sound.
باسل أحمد
باسل أحمد2024-08-23 22:04
The dealership said a recording was needed but didn't provide it. [Angry]
نايف نبيل
نايف نبيل2024-08-23 19:10
I added a bracket myself, and it helped a bit. The resonance issue with the Murano is inherent, a design problem that can't be completely fixed. If you can get a free replacement, go for it, there's no reason not to.
فهد بكر
فهد بكر2024-08-23 17:57
Some people say it's stronger with a mount added.
I went to check out the Lavida Pure Electric with a 346 km range today. The salesperson said the original price was over 140,000 RMB, but after the discount, it's 85,800 RMB. However, they also mentioned an additional charge of 3,000 RMB for the charging station and a combined fee of 2,000 RMB for licensing and service. But SAIC Volkswagen's official customer service said the charging station is supposed to be free. [Shocked] This is quite a trick.
I have a 2015 car, and both the right front and right rear doors are rusted through. Today, I went for maintenance and asked if I could replace the doors. After taking some photos and uploading them to the manufacturer, I waited for a while, and they said they could replace two doors for free! I don't have to pay a single penny. 😊😊
I'm an owner of a 2012 XV and haven't really been to the dealership much. A few days ago, I went to get a small part replaced, and the manager mentioned that there's a recall for this model. It requires replacing the valve springs and brake switch, but it seems too troublesome since it needs the engine to be taken out, so I didn't do it. Has anyone else gone through this? If I don't do it, will there be any impact?
Model X, 40,000 km. There's a consistent humming noise from the rear wheels while driving, most noticeable at speeds of 35-40 km/h. You can feel a slight vibration in the floor when sitting in the back seat. I've been to the dealership a couple of times for this, and the last time, the technician confirmed the noise. After checking, they said the half axles are fine and concluded it's due to tire aging. I've heard that 21-inch tires tend to wear unevenly and might need replacement around 40,000 km. The tires only have 40,000 km on them, and the tread still looks clear. Is this really possible?
The 2022 Haval H9 is approaching 40,000 kilometers, and I'm not sure how much longer the original spark plugs will last. Fellow car enthusiasts, at how many kilometers did you change your spark plugs? What condition were the spark plugs when you replaced them? Thanks! ***** Also, I've clearly stated it's the Haval H9 and posted this in the Haval H9 section. Please make sure it stays within the Haval H9 circle and not other H9 circles. It's really tiring, you're quite something! *****
I have a 2018 Outlander 2.4 AWD. Last month, the right front wheel got hit, and I had to replace the shock absorber, half shaft, and steering rack. 😒😒😒 Now, when I'm driving at around 110 km/h, the steering wheel vibrates in my hands. It's not exactly a shake, but more of a tingling feeling. The car doesn't drift or vibrate, just the steering wheel. If I grip the wheel tightly, it feels a bit better. There's no issue when driving below 100 km/h. I've done wheel alignment, and the data is spot on. I've also done wheel balancing and swapped the front and rear tires. I've even replaced the front bearings, but there's no change. The repair shop said the next step would be to start replacing parts one by one, but that would be too costly. Does anyone know what the problem might be? I'd be willing to offer a small reward for a solution. 😏😏😏
Yesterday, I went for maintenance and replaced the spark plug assembly. I want to ask, after a year and having driven 20,000 kilometers, is it necessary to replace it?
On the day of the Mid-Autumn Festival, the reverse camera and 360 stopped working. I went to the 4S shop the next day for recalibration to fix it. Because the steering wheel was vibrating while driving on the highway, I did a wheel balancing and four-wheel alignment. Today, while driving on the highway, I noticed that the speed range at which the steering wheel vibrates has expanded, and now the seat also vibrates above 124 km/h. Can any expert provide some guidance?
