عبدالرحمن رياض
2024-01-05 16:18
Hi everyone, I have a 2017 Murano and noticed that the steering wheel doesn't return to the center after turning. Is this normal for you guys? I just discovered this issue.
Comments( 8 )
عبدالله عَبْدُ الْعَزِيز
عبدالله عَبْدُ الْعَزِيز2024-11-09 22:51
Normally, with hydraulic ones, you often need to give them a little hand assist.
سعود مجدي
سعود مجدي2024-03-01 19:13
I have the same issue too.
سعود مجدي
سعود مجدي2024-03-01 19:12
Hey bro, have you sorted this out?
نايف أرسلان
نايف أرسلان2024-01-09 08:17
Power steering fluid needs to be changed.
شعيب حسن
شعيب حسن2024-01-08 14:42
Over time, remember to adjust the wheel alignment data of the chassis.
فهد أبشير
فهد أبشير2024-01-06 08:13
You should visit the 4S shop and have them take a look.
فهد بكر
فهد بكر2024-01-06 04:07
Not yet researched.
نايف نبيل
نايف نبيل2024-01-05 19:11
Mechanical assistance definitely isn't as smooth and consistent as electronic assistance.
What causes the steering wheel not to return to center automatically?
Hi everyone, I need some advice. I have a 2015 1.4T Touran with nearly 110,000 KM on it. Recently, in the past six months, I've noticed that when making U-turns or reversing into parking spots, there's a sudden large resistance when turning the steering wheel. This doesn't happen during normal driving, only when suddenly turning the steering wheel. Can someone help me figure this out? Thanks!
Does your Alto automatically return to the center when you turn the steering wheel?
HS 30T 2WD, when driving on the highway, the steering feels sticky and doesn't return to the center, making it tiring to constantly adjust. This doesn't happen at low speeds or in hot weather. Has anyone else experienced this? How did you solve it? Some say it's an issue with the steering gear and needs a full replacement—is this true?
Hi everyone, just wondering if the steering wheel of the Skoda Rapid doesn't return automatically when driving at low speeds?
Hi everyone, I'm thinking about replacing the center console in my Xiaozhi. Any recommendations?
Why is the steering on my 2018 X-Trail heavy and not returning to center automatically?
Steering feels stuck and doesn't return to center. How do you guys deal with this? I've heard it can be fixed by reapplying grease to the steering gear. How much does it roughly cost?
