Does the exhaust pipe deformation on the 2021 Murano affect its performance?
Pajero V93 chassis is leaking oil, and it's dripping onto the exhaust pipe. It needs repair.
Is your 2017 model with a 1.5L CVT having black residue on the exhaust pipe when you touch it? Does anyone else experience this?
Is the left side of the Jeep Compass exhaust pipe naturally lower, or does it need to be fixed?
4Does oil leakage from the engine hood of the 2014 Peugeot 301 affect its use?
5Does oil seepage from the engine cover of the 2014 Peugeot 301 affect its use?
6Does the 2021 Murano have a buzzing resonance at 1500 RPM? Should I go to the dealership to request a replacement of the exhaust manifold and bracket? Will not replacing the exhaust manifold cause it to crack?
7This pipe seems to be leaking oil. Does this happen to you as well? Also, what is the purpose of this pipe? Is it for exhaust gas recirculation?
8Does the exhaust pipe deformation on the 2021 Murano affect its performance?
9Does the 2021 Murano have heated side mirrors?
10How do you open the trunk from inside the cabin in the 2021 base model Murano? Does it not have this feature?
