Do any of you Murano owners experience uneven tire wear on the rear wheels? Mine has only run 28,000 kilometers and it's showing signs of wear.
Comments( 10 )
How many liters is the fuel tank for the 2018 Manual Comfort version? The official specification shows 60L, but mine only holds a little over 40L.
Hey car enthusiasts, have you noticed that after two years of running on 95, the wind and tire noise is really loud? It was only quieter when it was brand new. Does anyone have any solutions?
I want to ask real Model X owners, is the free supercharging nationwide? Theoretically, if you use supercharging on national highways, does it mean the only cost is vehicle wear and tear? (An immature idea: using a car with free supercharging for delivery and ride-sharing)
4How can I change the display on the left side of the dashboard screen? Mine always shows a car model, but I've seen others display tire pressure.
5How long does everyone's car battery last? Mine only lasts about two years before it runs out. Does the start-stop function consume that much power?
6Hello fellow car owners, regarding the Touareg 3.0, do you experience any jerking while driving? Mine sometimes has a jerking sensation.
7Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
8Is the Nissan X-Trail EP using a direct or indirect TPMS? If it's direct, after inflating the tires, it doesn't update the tire pressure immediately; it only shows the new pressure data after driving for a while, which seems a bit like the characteristics of ABS estimation. If it's indirect, it can still independently display the pressure of each tire, and the manual also mentions that the tire pressure display might be affected by wireless interference, which sounds more like the working principle of in-tire pressure sensors. So, I'm not quite sure why this TPMS needs to activate at speeds above 25 km/h.
9Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦♂️
10Hello CHR owners, what tire pressure do you usually maintain, around 2 point something? For summer and winter, I'd appreciate some guidance from fellow owners! I inflated mine to 2.6 the other day, is that a bit high?
