Can coolants be mixed?
What could be the reasons for a 2006 Suzuki Liana frequently losing coolant?
Hey fellow 207 owners, how's the Monroe suspension? I've seen mixed reviews online. 😂
Which coolant should I buy for the imported Koleos? I noticed today that the coolant in the reservoir is below the minimum line and I'm considering replacing it all. Could you advise on which coolant would be suitable?
4What color is the coolant for the 2017 Dongfeng Renault Koleos?
5What are the reasons for coolant leakage?
6If it's just for home use, and you're waiting for the mix to be ready, there's no need to insist on the 009.
7Why does it show high coolant temperature at startup? Unable to start.
82013 Peugeot 3008 1.6T version is consuming coolant too quickly, but no leaks can be found. Does anyone know what might be going on?
9Can coolants be mixed?
10How to change the coolant for a 2011 Mazda 6, and how many liters are needed?
