Where can I find professional installation services for a Magic Box, clean water tank, and other camper van systems for a Multivan?
"The electronic shift backup has been activated; please service soon." This message indicates that there might be an issue with the electronic gear shifting system in your vehicle. It's recommended to have it checked and serviced by a professional as soon as possible to avoid potential problems.
My 2018 automatic car with a turbo is losing engine oil. I've checked with the service center; there's no blue or white smoke from the exhaust, and there's no sign of oil leakage on the engine exterior. Both the oxygen sensor and spark plugs are clean. The service center couldn't find the problem. Anyone knows what might be wrong?
I just went to the 4S shop today, and I can't upgrade the car system. The original 360 camera is not clear and can't be calibrated. Regarding the transmission defect issue, the after-sales service at the 4S shop will apply to the manufacturer and get back to me. Also, I'm wondering if just changing the DSP will improve the original audio system since I don't like it. I'm considering the Pioneer 500A, which can connect directly with the original plug without installing separate loudspeaker wires.
4Where can I find professional installation services for a Magic Box, clean water tank, and other camper van systems for a Multivan?
5Can the 90 play videos using the car system? The built-in system cannot install other apps.
6To reset the tire pressure light on the MG GS 4WD, follow these steps: 1. **Check Tire Pressure**: Ensure all tires are inflated to the recommended pressure levels. You can usually find the recommended pressure on a sticker inside the driver's door or in the owner's manual. 2. **Drive the Car**: Sometimes, simply driving the car for a few miles can reset the tire pressure monitoring system (TPMS) if the tires are properly inflated. 3. **TPMS Reset Button**: Some models may have a TPMS reset button. Check your vehicle's manual for its location and instructions on how to use it. 4. **Professional Assistance**: If the light remains on, it might be necessary to have the system checked by a professional, as there could be an issue with the TPMS sensors. Please follow these instructions based on your specific vehicle model and refer to your owner's manual for more detailed guidance.
7With a budget of around 100, you are looking for a 992s with four-wheel drive, in white with a red interior or in silver. At this price range, you might be able to find a used car in decent condition. The exact condition will depend on factors such as mileage, year of manufacture, and maintenance history. It's recommended to check the service record and perhaps get a professional inspection before purchasing to ensure the car's quality.
8Has anyone successfully unlocked their car system? I'm looking to modify my car's system mainly to install third-party apps like Dudu Launcher. I'm hoping to find a tutorial on how to unlock the system's permissions without fully flashing it, as my current package is a lifetime deal, and I'm worried it might void it. Any advice from knowledgeable car enthusiasts would be greatly appreciated. Thanks! 🙏
9If your 2010 Suzuki Swift 1.5 automatic is still shaking after replacing the spark plugs, ignition coils, PCV valve, and EGR valve, there could be other issues at play. Some potential causes could be: - Engine mounts: Worn or damaged engine mounts can cause vibrations. - Fuel injectors: Clogged or malfunctioning fuel injectors can lead to engine misfires. - Throttle body: A dirty or faulty throttle body can affect engine performance. - Air intake system: Check for any leaks or blockages in the air intake system. - Transmission issues: Problems with the transmission can also cause vibrations. You may want to consult a professional mechanic to diagnose the issue more accurately.
10When you open the fuel cap of your 2014 ASX and hear a sound of air being sucked in, it could be due to the pressure difference between the inside of the fuel tank and the outside air. This is usually normal and can happen because the fuel system is sealed to prevent fuel vapors from escaping. If the sound is frequent or you're experiencing other issues, it might be a good idea to have it checked by a professional.
