What should I do if the small table inside my Multivan is stuck in the raised position and won't go down?
The trunk won't open, what's going on? Is there a switch inside? Thanks.
My car won't start. Does anyone know what's going on?
4What should I do if the small table inside my Multivan is stuck in the raised position and won't go down?
5My sunroof won't open, what's going on? I press the button, but there's no response at all.
6The sunroof of my 2017 MG ZS won't open, and there's also a leak inside the car. 😢😢😢😢
7Does anyone know why the rear window won't go up or down? Thanks!
8Help needed! My 2014 model key won't fit into the slot, what's going on?
9The fuel tank switch is pressed down and won't pop back up. How should I handle this?
10The car doors won't open, and there's no response inside. What's going on? The battery seems to be charged.
