سعود احمد
2021-05-22 12:44
Master, the right side electric door sometimes responds and sometimes doesn't. After manual operation, it works normally again. I've replaced the lock block, sensor seal strip, and sliding sensor. (290,000 kilometers) Any advice?
عبد العزيز مراد
عبد العزيز مراد2021-07-13 11:45
I'm on the left side 😂, even with manual it doesn't work sometimes and I have to force it.
20
حسين عرفات
حسين عرفات2021-05-22 14:41
The connection is not good, it should be at the lock block.
My M7's electric right middle door isn't working. It opens a little, and if I press it again, it opens a bit more, but it won't close completely. Experts, what could be the reason for this?
The side electric sliding door of the Multivan can open, but it doesn't respond when closing. What could be the reason?
When driving, if the car suddenly doesn't respond when you press the accelerator, and even flooring it doesn't increase the RPM, but releasing and pressing it again solves the issue, this could be a problem. When starting on a steep slope, if the car feels powerless and sometimes can't climb, requiring several attempts to increase RPM, there might be an issue to address.
My 2013 Sharan's electric door sometimes won't close by itself, and the button doesn't work either. After disconnecting and reconnecting the power, it works again. Does anyone know the reason?
Does anyone know why my 2014 Touran, which has 140,000 km on it, sometimes has the D gear light flashing while driving and the accelerator doesn't respond? I have to turn off the engine, switch to P gear, and restart the car to drive again. What could be causing this?
I've been driving a Touran for 7 years, and it's time for a change. I'm looking for recommendations based on my needs. Here's what I'm looking for: I commute 25km one way to work, and there's no fixed parking spot in my community. The city is crowded, which tests my driving skills, so the car can't be too big. I'd like a space for a nap at noon, so electric or plug-in hybrids are preferred. We are a family of three, and we often take the kid out on weekends, so the car's stability and smooth driving are important as my family gets car sick easily. I often take care of the kid alone, and since the kid is not very strong, an electric sliding door would be great. My kid likes camping in the car, so it needs to have ample space. Occasionally, I need to move things between houses, so flexible space is a plus. Since my wife doesn't drive, we can only have one car. Right now, it seems like the GAC E8 is the only option 🤣
