فهد قيس
2020-02-07 22:38
Is there anyone else experiencing noise from the middle door of the Multivan? If so, how did you solve it? (The noise seems like it's from the hard plastic of the door interior, making a creaking sound on rough roads!)
خالد اشرف
خالد اشرف2022-12-13 18:54
It's a common issue.
فخرو حسن
فخرو حسن2020-04-14 19:23
Wrap tape around the middle door lock pillar.
فهد عمار
فهد عمار2020-04-04 15:31
I have a noise coming from the rear door.
نايف عفان
نايف عفان2020-02-08 16:29
The noise on the left side stopped after I went to the shop and applied some oil.
نايف برهان
نايف برهان2020-02-07 23:01
If it's winter, you might hear this kind of noise. It's likely the sound of plastic parts inside the car door rubbing against each other. This can be tricky to fix, so you should check if there are any loose areas.
