فهد عين
2022-02-01 20:41
I'm looking for advice on my 2016 Volkswagen Multivan 4WD that's experiencing severe tire wear. I've done a wheel alignment, but it hasn't resolved the issue. Any insights would be appreciated.
عبدالله جلال الدين
عبدالله جلال الدين2022-02-05 13:32
Bushings, control arms
حسين عرفات
حسين عرفات2022-02-02 01:18
Stabilizer bar, bearing, control arm bushing, suggest checking them out.
I've been using the 2017 MDX for over a year, and the front tires are wearing out unevenly. After rotating the rear tires to the front and doing an alignment, the newly replaced tires are again showing severe uneven wear. Have any other car owners experienced this situation? Looking for advice.
Can a wheel alignment be done if the rear tires of a 2015 Sportage are wearing unevenly?
Looking to buy a 2018 or 2019 Volkswagen Multivan, preferably 4WD, but 2WD is also acceptable. Preferably in white. [love][love][love][love]
Looking for a 2016-2019 4WD Multivan in good condition. Budget is in the 30s! Preferably in the Beijing-Tianjin-Hebei area! Cash ready.
Has anyone experienced the same issue with the 2016 Jeep Renegade? When driving at speeds of 60-80 km/h over manhole covers or bumpy roads, the rear end feels loose (swaying side to side). The car hasn't been in any accidents, the rubber bushings seem fine, and the wheel alignment data is normal.
My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
Hello, does the Volkswagen Multivan T5 2016 have an automatic locking feature? How do I set it up?
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
Hi everyone, I have a 2015 Volkswagen Jetta with a manual transmission. I'm having trouble turning the key in the ignition; it takes several tries and some jiggling to get it to turn. Does anyone know what might be causing this? Any advice would be appreciated. Thanks!
