Hi everyone, my T6 has run 130,000 kilometers. Now the air conditioning sometimes doesn't cool, but it's occasional. When I take it for repairs, everything checks out fine. Has anyone else experienced this situation?
Hi everyone, sometimes my Mazda 2 sedan has a hard time starting, but it only happens occasionally. It struggles on the first attempt, but starts up easily on the second try. What could be the issue here?
My car has a weird problem. Sometimes it takes two tries to start. What could be the issue?
4The loudspeakers in my RDX are making a popping sound and sometimes they fail. Previously, there was an occasional popping sound when starting the car cold, but recently it happens every time I start the car. The car's Bluetooth seems to be working fine, and the screen shows that music is playing, but there's no sound. Sometimes restarting the car fixes it, but sometimes it doesn't. This is happening more frequently now. Has anyone else experienced this? What could be the issue?
5Geely sometimes has no response when starting, but the dashboard and electrical components are powered. It happens occasionally. Is there a solution?
6Is the issue with the Levante's air conditioning not cooling occasionally, sometimes not cooling at all, and then starting to cool again after driving at higher speeds, related to a common compressor problem?
7Has anyone experienced this situation? (The lights flicker while driving, the battery is fine, it's not the automatic headlights, and it doesn't happen very often. A roadside repair shop moved the headlight's fuse, but the problem still hasn't been solved.)
8Help needed! I have a 2017 model 95. With summer here, there's white smoke coming out at startup, but it goes back to normal after a few seconds. There's no lack of oil or water, and the computer diagnostics show everything is fine. I've been to several repair shops, but no one has found the problem. Has anyone else encountered a similar issue?
9Yesterday, I went to the dealership to check the air conditioning pressure. It was at 16 psi and the temperature was 7.6 degrees, and they said everything was fine. But by noon, it wasn't cooling anymore. 🤦♂️
10Anyone else experiencing occasional rattling noises from the 24 model's dashboard? It sometimes goes "dang dang dang," but when I take it to the dealership, the noise disappears and they can't find the issue.
