Will the brake lights illuminate during regenerative braking when you are not pressing the brake pedal?
Why does the electronic brake on the MG GS get damaged when you press the brake pedal to release it?
What could be the reason that there seems to be something blocking the brake pedal when I press the brake on a 207?
4What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
5When driving a Vitara 4WD at high speed and braking, do you experience feedback or a pulsation in the brake pedal?
6Will the brake lights come on in the strong regenerative braking mode?
7Fellow car enthusiasts, have you ever experienced the brake pedal bouncing back a few times when you press it down?
8I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
9Is it normal for the brake pedal of the Nissan X-Trail Classic to make a loud noise when it rebounds and contacts the brake light switch?
10In a 2021 manual Santana, when you turn on the ignition, the battery and engine lights will illuminate, but they disappear once the engine starts.
