How is the warm air in the MG4 activated? When the outside temperature is 17°C, if I don't turn on the AC and set the air output temperature to 28°C, will warm air come out? It's the same even if I turn on the AC. It worked once with warm air coming out, but now even with everything off, the power consumption has increased. Has any experienced driver studied the warm air system?
When you press and hold the AC button on the Arrizo 3, the compressor works and cool air comes out. However, once you release the button, it automatically springs back and the button light doesn't turn on. What could be the issue?
What could be the issue if the air conditioning compressor keeps running even when the AC switch is properly turned off? Does anyone know?
Is anyone else experiencing unstable idling with the new BRZ? Even without the AC on, whether the car is cold or warm, the gauge needle fluctuates noticeably.
4For the 2017 GWM Haval model with 110,000 km, if the air conditioning isn't blowing air until the fan speed is set to maximum, or the AC needs to be turned off for a few seconds before air comes out, there might be an issue with the blower motor or the air vents. It's best to have a professional check the blower motor and the vent system for any blockages or mechanical issues.
5The fan on my Sharan sometimes doesn't turn on even when the temperature is high. What could be the reason? Any advice?
6Does anyone know how to adjust the Hongqi H7 when the front row has warm air and the back row has cold air?
7My 207's automatic air conditioning is having issues. The air only blows towards the windshield and can't be switched to other directions. The display on the panel works, but it doesn't actually change. The AC compressor starts, but it keeps blowing hot air. The temperature adjustment panel shows the settings, but the temperature doesn't change.
8Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
9Hey everyone, the AC isn't blowing any air, and there's no air coming out on internal circulation, only natural airflow. Have you encountered this before? Is it the blower that's broken? I saw online that there could be many reasons. Is it necessary to replace the blower with an original one?
10To turn on the heater without the AC light coming on, you usually need to adjust the settings on your car's climate control system. Make sure that the AC button is turned off. If your car has an automatic climate control system, try switching to manual mode and adjusting the temperature and fan settings manually. If the AC light still comes on when you activate the heater, it might be due to the car's design to dehumidify the air, in which case you may need to consult your vehicle's manual or contact a service center for further assistance.
