عبد العزيز مأمون
2024-11-06 12:53
How do I set the MG4 Champion Edition to automatically stop charging at 90%? When charging regularly, is it beneficial for the battery to charge only to 90% instead of fully charging?
Comments( 6 )
سلمان محمود
سلمان محمود2024-11-15 21:10
With the manufacturer's charging pile, you can manage energy in the car system. You can set the battery to 90%, but it's not necessary. Since I drive every day, I just plug it in at night to fully charge and use it in the morning. It's not like I charge it fully and then don't use it.
محمد مكرم
محمد مكرم2024-11-15 17:11
No, it actually tends to cause problems.
سلمان محسن
سلمان محسن2024-11-15 15:55
In-car settings
عمر أيوب
عمر أيوب2024-11-06 21:29
With the current lithium iron phosphate batteries, there's almost no need to worry about overcharging affecting their lifespan. However, when fully charged, there's no energy recovery, which can lead to slightly longer braking distances.
فهد بلال
فهد بلال2024-11-06 13:03
LFP battery, fully charged is fine.
حسن أنور
حسن أنور2024-11-06 13:02
It's best to fully charge lithium iron phosphate batteries periodically to calibrate the capacity.
