Can the windshield washer nozzles be adjusted? It's wasting too much fluid.
Is the clutch too heavy? Can it be adjusted to be lighter?
Does anyone know which fuse is for the Chery Kairui X3's windshield washer motor?
4The washer fluid on my Rapid is spraying too coarse and too low, hitting below the wiper blades. How can I adjust it to spray finer and higher?
5The windshield washer spray on the Rapid is too coarse and too low, spraying below the wipers. How can I adjust it to be finer and higher?
6Where is the rear glass washer nozzle? It always drips down instead of spraying upwards. 🤔
7Which button on the Ghibli can spray the windshield washer fluid? I've tried the wipers, they work, but I don't know how to spray the fluid. Can any fellow car enthusiasts tell me? Thanks!
8BYD Song Plus 2.0 Fuel version, the windshield washer fluid doesn't spray out, but after driving for a while, it starts working again. What could be the problem?
9What could cause the 2014 Peugeot 308 to not spray windshield washer fluid? Is it the lever on the right side of the steering wheel that needs to be lifted forward for a few seconds? I can't find the spray nozzles, so I'm considering using a needle to check if they're clogged. Any advice from the experts?
10Peugeot 3008 windscreen washer not working? I've already added three bottles of fluid.
