علي قادر
2024-11-20 10:43
Can changing to Michelin tires solve the resonance problem?
برهان عبدالله
برهان عبدالله2024-11-22 14:31
Design flaw
حسين بوتفليقة
حسين بوتفليقة2024-11-20 14:08
When driving on bumpy roads with a fully loaded vehicle, if you speed up a bit, it might help. I drive over a kilometer of washboard road every day on my way to work. I press the accelerator hard, and after a while, the chassis bushings loosen up, reducing the stress. Now, after over 20,000 kilometers, there's no more vibration.
سعود معتصم
سعود معتصم2024-11-20 12:53
It's useless, it's not the tire issue.
Help! When driving on slightly rough roads, the gear shift shakes a lot. Is there any way to fix it? I'm willing to offer a reward for anyone who can solve this problem!
How many kilometers should I drive before changing the tires?
Is there anyone with a 2020 GA8 experiencing occasional engine shaking and exhaust fault codes? How did you solve the problem?
How do you solve the brake squeal problem? What should be replaced?
After changing the brake fluid in my GAC GS5, the brakes failed. I thought it might be an issue with the master cylinder, so I replaced it, but the problem still wasn't solved. Can any experts offer some help?
How to solve the problem of loud noise?
If you want to modify your tires without changing the 17-inch diameter, you can consider changing the tire's width or profile. You can opt for a wider tire for better grip or a different profile for improved performance. Just make sure the new tires fit your vehicle's specifications and don't affect the overall driving experience. It's always a good idea to consult with a professional or refer to your vehicle's manual for recommendations.
Has anyone changed tires? Which tires are good?
Touareg 3.0, after over 20,000 km, experiencing differential resonance when turning. The dealer isn't resolving it, saying it's a design flaw. The differential is smaller than before. Changing the differential oil can temporarily fix it, but the resonance returns after another 20,000-30,000 km. Do you guys have this resonance issue with your cars?
How to solve the problem of burning oil?
