Picked up a Model Y Long Range on March 18, 2023. Current mileage: 65,367 km. When new, the range was 520 km at 100% charge until May 2023. Now, at 100% charge, the range is 470 km. In just 6 months, the battery has degraded by 10% (a loss of 50 km in range). Fellow owners, is your car experiencing the same issue?
For a 2018 Model S 100D with 80,000-90,000 kilometers, the remaining battery range can be significantly different compared to a 2022 Model 3 or Model Y with a 78 kWh battery. The older Model S may experience some battery degradation over time, affecting its range. When considering a used car, it's understandable to be concerned about the battery's performance and capacity.
Hey folks, has anyone experienced their V40 shaking at speeds between 100 to 120 km/h, but then it stops shaking once it hits 150 km/h? I have an 18 model T5 with 55,200 km on it.
How do you guys manage to get 6 or 7 liters per 100 km? I filled up until the pump clicked off, drove 140 km, and already lost one bar of fuel. It's consuming more than 10 liters per 100 km 😭😭😭
4Can a home charger for the 2017 X90D charge the 2023 X Long Range?
5Cullinan or Model Y? The Cullinan looks very grand, but the Model Y, being fully electric, saves on fuel costs and also has an advantage in terms of acceleration from 0 to 100 km/h. I'm torn.
6I always charge when my battery is between 10-20%. I see many people start charging at 30%. Does charging at 30% really help protect the battery better? And do you guys wait until it’s 100% full before unplugging?
7How long does it take to fully charge the E2 with a slow charger? The range is 405 km.
8To achieve a 690 km range, how many kilowatt-hours (kWh) are required for a full charge?
9Is the Toyota bZ3 2023 Long Range PRO with 19,000 km non-commercial use worth 119,000 for home use?
10What is the actual range of the 2023 Model X with 700 km?
